  • 접속자 16
2021.06.10 13:29 4,774 0
[문제점]
[테스트]
이어폰 유닛중 R만을 꽂아서 연결 -> 이상 없음.
이어폰 유닛중 L만을 꽂아서 연결 -> 증상 동일.
이어폰 유닛 L을 R케이블쪽에 연결 -> 증상 동일.
[결론]
닥터캣 8,619 2021.06.21
닥터캣 2,496 2021.07.13
닥터캣 5,980 2021.12.31
닥터캣 9,994 2021.12.31
닥터캣 10,530 2021.12.31
닥터캣 12,502 2021.08.18
닥터캣 76,335 2021.08.12
닥터캣 9,179 2021.08.11
닥터캣 20,223 2021.08.06
닥터캣 5,006 2021.07.21
닥터캣 10,572 2021.06.28
닥터캣 5,313 2021.06.25
닥터캣 5,162 2021.06.23
닥터캣 22,775 2021.06.11
닥터캣 4,775 2021.06.10
닥터캣 16,162 2021.06.08
닥터캣 16,453 2021.06.02
닥터캣 20,093 2021.06.01
닥터캣 10,622 2021.05.27
닥터캣 6,223 2021.05.25
닥터캣 4,172 2021.05.20
닥터캣 11,358 2021.05.17
닥터캣 36,367 2021.05.17
닥터캣 6,498 2020.12.21
닥터캣 6,832 2020.12.21
닥터캣 5,565 2020.12.21
닥터캣 5,314 2020.12.16
닥터캣 4,404 2020.12.03
닥터캣 12,245 2020.11.26
헬사넷 4,686 2020.11.16
